Monitor Process Automation without a PC
CAS DATA LOGGER's Delphin Technology AG data acquisition systems promote effective process monitoring to avoid downtime, ensuring product quality and maintaining production volume. Delphin's Message and Expert devices combine analog and digital inputs and their capability to acquire process data via Profibus, Modbus, and OPC and can record and report limit value violations directly, without the need for PC support. Limit value violations also can be portrayed in an alarm list. The data is permanently and securely recorded to a Delphin ProfiSignal database, as well as held in the device’s non-volatile memory.
Application features include independent acquisition and monitoring for an infinite number of channels; Profibus, Modbus, and OPC UA interfaces, an alarm database with lists of alarms and events; fault reporting via email, text messaging, and digital outputs; and DataService databases for continuous and/or batch recording.
All data is archived to a server. Recording and monitoring stop as soon as temperatures drop below 90°C (194°F). Access to data on completed charges is available from any PC workstation.
Delphin data acquisition systems feature different analog and digital I/O modules that can be used with a range of signal types, including voltage, 4-20 mA current, thermocouple, RTD, and resistance. They also offer powerful alarm and programming capabilities, so these instruments ca process measurements and initiate actions completely independently.
Delphin systems can be used for local data acquisition and logging when connected to a PC, for remote unattended data collection connected the internet, or as standalone devices.
Learn more at www.dataloggerinc.com
