Simple Filter-Change Wet-Dry Vac
The EasySwitch uses minimal volumes of volume of compressed air to create a powerful pneumatic vacuum or any medium — wet materials, dry materials, light volume or heavy volumes — with fast and tool-less conversion between functional modes.
The EXAIR CORP. EasySwitch Wet-Dry Vac simplifies the filter change process when switching from vacuuming a dry material to a liquid or vice versa. Using a minimal volume of compressed air, the EasySwitch is a powerful pneumatic vacuum that is ideal for any application—wet, dry, light, and heavy.
The fast and tool-less conversion to vacuuming liquids is done by releasing one latch, removing the filter element, and securing the latch. Simply reinstall the filter into the lid assembly for dry materials.
The EasySwitch is designed to handle tough industrial cleanup jobs easily. It rests upon any 55-gallon drum. With a patent-pending design, the EasySwitch vacuum uses a standard or HEPA-certified filter when vacuuming dry material.
The EasySwitch creates a powerful vacuum (yet, it's quiet at 79 decibels) without the need for electricity.
Because the vacuum generator has no moving parts and uses no electricity, there will be little concern for part failure, motor failure, or working with liquids associated with electric industrial vacuums. Learn more at www.exair.co/easys
