HEPA Vac Simplifies Vacuuming Wet and Dry Materials
EXAIR CORP.’s new EasySwitch® HEPA wet-dry vac simplifies the filter-change process when switching from vacuuming a dry material to a liquid, or vice versa. Using the minimal volume of compressed air, the EasySwitch is a powerful pneumatic vacuum ideal for any application – wet, dry, light, or heavy.
The EasySwitch is designed to handle tough industrial clean-up jobs with ease, using a HEPA-certified filter when vacuuming dry material. It rests upon any 55 gallon drum.
With Exair’s patent-pending design, the fast and tool-less conversion to vacuuming liquids is done by releasing one latch, removing the filter element, and securing the latch. Simply reinstall the filter into the lid assembly for dry materials.
The EasySwitch vacuum creates a powerful vacuum (at just 79 decibels) without the need for electricity. Because the vacuum generator has no moving parts and uses no electricity, there is little concern for failed parts, motor failure, or working with liquids associated with electric industrial vacuums. Learn more at www.exair.co/esvhepa
