Single-stage compressor
With energy efficiency system heat recovery
SULLAIR'S 7500 S-energy series with energy efficiency system heat recovery has proven most effective in reducing total life cycle costs, more than other compressors of similar design and horsepower. Contributing to the energy savings is Sullair's time-tested air-end design with the low restriction inlet valve, low pressure drop air-fluid separation system that prevents energy loss, and a high efficiency fan.
