Vibration Mounts
ADVANCED ANTIVIBRATION COMPONENTS' new series of double studded silicone vibration mounts feature superior damping performance. The mounts are designed for light to medium loads from 2.8 to 7.2 lbs, (up to 75% 16.5-27.6 lbs per mount). Their highest damping effect arises when the gel is compressed 10% up to 30%. The mounts are able to operate effectively over a wide temperature range from -400 to 392 degrees F.
