Industrial Vacuum Cleaner
VAC-U-MAX’s 55MW is a complete system that increases coolant life as well as extends machine tool filtration systems by cleaning fluids and removing metal chips and swarf at 1-2 gallons per second. With the turn of a lever, the 55MW pumps ...
VAC-U-MAX’s 55MW is a complete system that increases coolant life as well as extends machine tool filtration systems by cleaning fluids and removing metal chips and swarf at 1-2 gallons per second. With the turn of a lever, the 55MW pumps out liquid contents of the drum through the discharge hose to a central filtration system for coolant/oils or approved floor drains up to 14 gallons per minute. The dispensing nozzle on the pump-out hose puts the operator in control of where and when the fluid comes out.
www.vac-u-max.com
