Anti-Stick Agent
For easy removal of gaskets from flanged joints
Nov. 3, 2008
GARLOCK SEALING TECHNOLOGIES' Flange Free anti-stick agent facilitates removal of gaskets from flanged joints. The new material is a high-temperature, inorganic coating that dramatically reduces the time and effort required to remove items after extended services. It is fused to the surface of the gasket material and doesn't contain chemicals that can cause the gaskets to crack or otherwise degrade.
