Floor Scales
Handle severe loading
July 22, 2008
ALLIANCE SCALE'S floor scales feature 6-in. structural steel channel frames welded to tread plate decks for optimum rigidity and minimum defection under severe loading conditions. Easy to access for leveling, all load cells are recessed within a channel, cables are routed in protective conduits, and the junction box is mounted on a handy slide-out tray. Features simple to operate keypad indicators.
