Portable Emissions Analyzer with Heated Sample Line
A complete portable system for EPA-compliance-level emissions monitoring and testing of combustion systems.
The new, E INSTRUMENTS INTERNATIONAL LLC E9000 emissions analyzer with heated sample line is a complete portable system for EPA-compliance-level emissions monitoring and testing of combustion systems, including furnaces, burners, boilers, engines, and so forth.
The E9000 is recommended for regulatory and maintenance use, with up to nine total gas sensors; electrochemical sensors for oxygen (O2), carbon monoxide (CO), nitric oxide (NO), nitrogen dioxide (NO2), sulfur dioxide (SO2), and hydrogen sulfide (H2S.)
The unit has NDIR sensors for carbon dioxide (CO2), hydrocarbons (CxHy, HC), and high CO. It is provided with a heated probe head and sample line, internal thermoelectric chiller with automatic condensate removal, ad internal data storage memory for up to 16,000 tests.)
The E9000’s built-in printer uses non-fading paper, and the Android app makes it possible to easily monitor and save data. The native software is capable of automatic data logging.
The E9000 emissions analyzer is described as “low-NOx and true NOx capable,” with pre-calibrated gas sensors. Learn more at www.E-Inst.com
