PALMER MANUFACTURING’s Flip Molding Machine (FMM) system, like its Universal Molding Machine, is designed to support a high-production-rate, no-bake molding operations, with low capital costs. It will produce no-bake molds with any tooling, with minimal set-up requirements and minimal tooling modifications.
In jobbing foundries, all products are variable. Tooling may be new or old, cope-and-drag, matchplate, green sand, no-bake, shell, metal, wood, plastic, or some combination of these. Quantities may range from one or two pieces up to hundreds or thousands.
The FMM uses cast-iron tooling plates designed to accept cope-and-drag and no-bake boxes. Production rates of 30 molds per hours are easily achieved with a four-station FMM, with one or two operators, depending on the particular needs for mold preparation.
The FMM achieves a high mold-production rate without a rollover. Because the pattern is inverted automatically and drawn onto a precision scissors lift, a rollover is not necessary and any amount of daylight is available, at no additional expense.
The four-station FMM is applicable for molds sized 12x12 4/4, to 60x60 36/36, with mold depths up to 36 in.
Learn more at www.palmermfg.com
