Flexovit USA
FLEXOVIT USA INC., manufacturers of high-productivity grinding wheels, flap discs, and other abrasive products for portable power tools, has introduced CAPSTONE™ — a patent-pending, cupwheel alternative to Type 6 and Type 11 cupwheels. It is designed to be used on the same tools and in the same applications as non-reinforced cupwheels but is fully reinforced for maximum safety.
The Capstone™ achieves a fast metal-removal rate with less pressure, and without gouging the work surface.
Capstone™ wheels fit completely under Type 11 guards. They are built with four full layers of high-tensile fiberglass reinforcement for maximum workplace safety.
Learn more at www.flexovitabrasives.com
