WALTER SURFACE TECHNOLOGIES introduced CleanBox Flow to its Bio-Circle series of manual industrial parts washing systems. Suitable for the bulk cleaning of small- to medium-sized parts, the compact-sized CleanBox Flow is specially designed for use with Bio-Circle CB 100, the powerful, natural water-based solvent that is biodegradable and VOC-free. Together, the CleanBox Flow and CB 100 offer a safe, efficient, cost-effective, and eco-friendly replacement to solvents in virtually any type of MRO environment.
The CleanBox Flow system helps contribute to a safer and healthier working environment by cost-effectively replacing the need for harsh industrial solvents. The CleanBox Flow and CB 100 help improve the health and safety of workers by minimizing dangerous chemicals that create fire hazards and toxic exposure risks, while also reducing the need for costly waste removal, ventilation systems and insurance policy premiums.
The CleanBox Flow parts washer system consists of a sink and flow-through cleaning brush, a basin and heavy-duty pump that circulates through heavy oils, greases and contaminants. When paired with CB 100, the CleanBox Flow allows quick and easy removal of hardened greases, oils, and residues on small to medium industrial parts. Its heavy-duty construction and ergonomic design withstands rugged manufacturing environments.
The CleanBox Flow is an entry-level system that is supplied with an array of accessories making it versatile for a wide range of customer uses:
• The Bio-Circle Air gun assists quick drying of industrial parts, reducing the risk of flash rusting;
• The CleanBox Flow two-level cart puts the parts washer at the ideal height for working and makes the system mobile;
• The CleanBox Flow lid prevents dust and other contaminants from entering the system.
The system is compact and allows for easy storage in any work environment.
The CB 100 is an all-natural, water-based solvent and is considered an advanced technology emulsion. CB 100 contains Nature Boost, Bio-Circle’s exclusive new raw material derived from vegetable extracts that acts as a natural solvent with water to create an extremely powerful natural cleaner and degreaser. CB 100 easily removes greases, stubborn ink, rubber marks, tar, wax, carbon, soot, pastes and many other industrial contaminants. Its ready to use formula provides impressive cleaning potential at room temperature making it the obvious choice for manual cleaning, cleaning by immersion or pre-soaking as well as for use in ultrasonic baths. CB 100 is non-corrosive, bio-degradable and NSF-certified. It is compatible with steel, stainless steel, aluminum, and nonferrous metals.
Visit www.walter.com or www.biocircle.com
