Heavy-Duty Machining
TOYODA MACHINERY s BM-1200 VMC delivers superior performance for heavy-duty machining of ferrous material. The rigid iron base is paired with four Y-axis box guideways to eliminate saddle overhang while the extra-wide column expands machining ...
TOYODA MACHINERY s BM-1200 VMC delivers superior performance for heavy-duty machining of ferrous material. The rigid iron base is paired with four Y-axis box guideways to eliminate saddle overhang while the extra-wide column expands machining capability. The direct-drive 12,000 rpm, temperature-controlled spindle is paired with the powerful Fanuc 18i-MB control to meet the demands of complex die/mold applications.
www.toyoda.com
