Vacuum Heat Treating System
Featuring a 7,000 lb. hearth capacity
Feb. 3, 2009
ALD-HOLDCROFT'S ModulTherm is available in a new "super-sized" model, measuring 36x36x72-in. and with a hearth capacity of 7,000 lbs. This version will also be available with high pressure gas quenching, oil quenching, intensive quenching, or even interfaces to press quenching. The automatic vacuum processing of this load size offers for the first time the ability to process large parts, large loads, and large production volumes.
