Masking Material
DYMAX CORP.'s SpeedMask UV curable masking resins are easy-on, fast-off masking systems that provide thorough and effective surface protection from contamination caused by acids, alkalines, plating solutions, and ambient debris from air plasma ...
DYMAX CORP.'s SpeedMask UV curable masking resins are easy-on, fast-off masking systems that provide thorough and effective surface protection from contamination caused by acids, alkalines, plating solutions, and ambient debris from air plasma spray, HVOF, grinding, peening, and grit blasting. It is solvent-free, non-flammable, urethane-based and water-soluble, available for use in manual or automatic applications in a variety of gel, brush-on, or spray-on formulations in a wide range of viscosities.
www.speedmax.com
