Vibratory Feeders Designed for Tough Jobs
Material-flow rates may be adjusted — variable or fixed — as necessary; custom-length troughs and special trough designs are available, too.
BEST PROCESS SOLUTIONS INC. vibratory feeders are designed to convey products smoothly, offering an adjustable flow-rate for materials, flow rates that may be variable or fixed, as necessary.
Available in electric or air-operated models, BPS heavy-duty vibratory feeders are designed with above-, below-, or side-mounted drives and can be arranged for base mounting or overhead suspension. Feeders are offered with custom-length vibrating troughs, and special trough designs are available, too.
Several basic models are available, including air-operated light duty, air-operated heavy duty, twin-motor vibrating pan and grizzly feeders, electromagnetic, twin motor and special application feeders.
Other options include the BPS Inertial Isolation System™ that is designed to eliminate the transfer of vibratory energy, to support structures and buildings.
BPS manufactures a complete line of custom-engineered, bulk-processing equipment and systems, and has more than 100 years of combined experience. It serves a wide range of dry processing industries, from chemicals and food to aggregates and recycling.
Learn more at www.bpsvibes.com
