Leadership Drives Transformation Failure
Key Highlights
- Most transformation failures stem from leadership not becoming the core performance system, leading to reversion after initial implementation.
- Success follows when leaders align on individual and collective accountability, ensuring they operate within the new performance system.
- Transformations should be viewed as systemic transitions, focusing on capabilities, behaviors, and decision-making structures rather than just milestones.
- Effective leadership involvement includes changing operating rhythms, clarifying decision rights, and fostering real-time accountability.
- Organizations succeed when leaders change how they lead, making their behaviors and decisions central to sustaining transformation outcomes.
Every year, boards approve transformation programs with confidence. Frameworks get delivered. Executive teams align on roadmaps. Launch events generate genuine momentum.
Then the program begins to drift. Milestones slip and energy dissipates. The organization absorbs the language of change without ever changing.
Two years later, an honest post-mortem would reveal what no one said at the launch: the program was designed to fail.
The failure of transformation programs is not caused by bad strategy, inadequate budgets or insufficient technology. It is caused by a design flaw that most organizations never examine because it is invisible inside the very assumptions they make to deliver the transformation: The leadership team sponsors the transformation instead of becoming the performance system at the center of it.
The Design Flaw
RAND Corporation’s 2026 research puts the transformation failure rate at 80%. More telling is that leadership drives the failure. Fully 73% of failed initiatives lack clear executive alignment on success metrics, and 56% lose active C-suite sponsorship within six months of launch.
Most transformation programs are built around a destination: Define the future state, build the roadmap, execute the roadmap, declare success when the new state is achieved.
Although this might feel sound, it is also what causes programs to fail. Delivering a new state and building the performance system that sustains it are two completely different organizational challenges. Most programs are resourced and measured to accomplish the first, while almost none are designed to accomplish the second.
What happens is predictable: the transformation team delivers the new operating model or technology platform, the initiative is marked complete and ownership transfers to the business. Over the following 12 to 18 months, the organization gradually reverts far enough that the investment never delivers what the board approved it to deliver. The destination was reached. The system that would have made it permanent was never built.
What the Leadership Team Actually Needs to Build
A transformation is not a project. It is a transition from one performance system to another. Projects end. When a transformation is treated as a system transition, the design questions change entirely: What capabilities, behaviors, and decision-making structures does the new state require? Progress is measured by organizational readiness, not milestone completion. The program is resourced to build sustainable infrastructure, not just deliver an outcome.
This requires something most transformation programs never develop: an executive leadership team aligned not just on the destination, but on their individual and collective accountability to sustain it. In nearly every transformation that falters, leaders are aligned on vision but not on what each of them personally owns and what the team’s shared accountability is when it is not.
What This Looks Like in Practice
Ammunition Manufacturing: The largest marketplace and ammunition manufacturer launched a transformation to shift from a saturated caliber market to an underserved emerging market and fulfill a major international contract. The engagement centered on building leadership team consensus and commitment around a master business plan, establishing a clear accountability structure and designing a Sales, Inventory and Operations Planning process to deliver predictable profitability.
Outcome: Asset uptime improved 42%, labor costs fell 5%, the company secured a $10.8M contract extension, and exit valuation increased 35%.
Flexible Packaging: A $3B private equity–owned manufacturer needed to bring EBITDA percentages in line as the holding matured. The organization — a result of three prior integrations — had a significant cultural challenge. Work centered on coaching the CEO and team in ownership, accountability and forward-looking decision-making.
Outcome: Facility leadership shifted from passive management to active ownership of the operating model, delivering a 700 basis point EBITDA improvement across 28 facilities.
In both cases, the turning point was the same: the leadership team stopped sponsoring the transformation from a distance and started operating as the performance system at the center of it.
The One Thing
If there is one change that separates transformation programs that succeed from those that fail, it is this: The leadership team becomes the performance system, not just the sponsor.
Most programs are sponsored from the top and executed in the middle. This works for projects. It does not work for transformations because the behaviors, decisions and cultural signals that determine whether the new state becomes permanent are generated at the top of the organization.
When senior leaders are genuinely inside the performance system, the program has a fundamentally different chance of success. Organizations do not transform because they launch programs. They transform because their leaders change how they lead, consistently and visibly, in service of a performance system that will outlast any initiative.
Three Action Steps for Leadership Teams
Audit accountability before you audit the program. Map what each member of the executive team actually owns—not their title, but their specific decision rights and performance commitments. If that map can’t be articulated clearly, build it first.
Change the operating rhythm to reflect the transformation. Most leadership teams review progress in the same format they use for everything else. Transformations require a dedicated rhythm where executives are making real-time calls, not receiving status updates.
Invest in the leadership team as a performing unit. The team that sponsors a transformation and the team capable of sustaining one are not automatically the same. Identify and close behavioral gaps—decision clarity, cross-functional trust, real-time accountability—with the same rigor applied to operational gaps.
Paul Kreis
Managing Partner, Brooks International
Paul Kreis is a managing partner and organizational development executive at Brooks International, specializing in leadership team development and organizational effectiveness, with deep experience across defense, manufacturing, and complex enterprise environments.
Related
Factory workers review plans together.
