Bi-Metal Band Saw Blades
L.S. STARRETT CO. Intenss bi-metal band saw blades are for general purpose metal sawing of a wide range of materials and shapes. Featuring a patented process developed by Starrett called bi-metal unique technology, which provides 170% more weld contact with the teeth, Intenss blades exhibit superior resistance to tooth strippage, reducing fracture and breakage to enable exceptionally long blade life. Performance is further enhanced by M-42 teeth with a multi-edge tooth design that produces split chips for faster cutting.
Intenss bi-metal blades are available in 1/2, 3/4, and 1-in. widths and 0.025 and 0.035-in. thicknesses. Blades in 1-1/4 or 1-1/2 in. widths and 0.035 and 0.042 in. thicknesses are also available, without the bi-metal unique feature. Intenss blades are offered in pitches of 10, 14 or 18, and 2-3, 3-4, 4-6, and 5-8 variable pitches. Coil lengths are available in 100 (30), 150 (45) or 250 ft (75 m), depending on blade widths. Learn more at www.starrett.com
