Round Tool Grinding Wheels Increase Stability
A more stable grinding process offers efficiency and part quality with less sub-surface damage, and a new resin bond combines wear resistance with the dressing ability of a standard resin bond.
SAINT-GOBAIN ABRASIVES’ Norton Winter V-PRIME Grinding Wheels are designed to provide edge stability and long life when gashing and clearance-grinding round tools. A more stable grinding process offers greater efficiency and better part quality with less sub-surface damage. The innovative V-PRIME resin bond combines exceptional wear resistance with the dressing ability of a standard resin bond.
The grinding wheels significantly increase productivity and reduce cycle times due to requiring lower grinding forces and permitting higher feed rates. User-friendly off-line dressing optimizes grinding wheel preparation, saving time and cost. The wheels also offer an excellent price/performance ratio.
Norton Winter V-PRIME Grinding Wheels are available in a range of common shapes and sizes for resin bonds, and in grits including 240, 320, and 400. The wheels can be customized for specific customer requirements. Learn more at www.nortonabrasives.com
