Titan Tool Supply
Titan RX-3 stereo microscope
Ergonomic Stereo-Microscope for Inspection, QC
Aug. 14, 2019
Versatility for research, assembly, burring, miniature machine work, and more
TITAN TOOL SUPPLY INC. introduced a new, ergonomic stereo-microscope that provides versatile inspection viewing for research, assembly, burring, electronic board soldering, miniature machine work, and other quality-control inspections.
Model RX- 3 features an eight-way adjustable pillar stand that allows for horizontal, vertical, and angular positioning that combines both planes with full 360-degree rotation on all adjustments with no limitations.
The RX-3 stereo microscope has a binocular tube with Diopter adjustment of +2 and variable, interpupillary adjustment. An extra-wide field, 10X eyepiece is standard with the unit.  A 20X eyepiece and 10X and 20X crosshair eyepieces are optionally available.
A 1X built-in objective also is standard. 0.5X, 1.5X, and 2X external objectives and a ring light adapter may be purchased separately. Images are right side up, and lenses are hard- coated with color correction, according to Titan Tool Supply.
Learn more at www.TitanToolSupply.com.
